It is currently Sat Jul 19, 2025 9:38 pm
PostPosted: Tue Jan 17, 2006 4:55 am
Hi
I am considering building a 12 string guitar. My music teach has been
wanting one for a long time and I thought I might suprise her by making one
for her. I have a Scott Antes 12 string drednaught plan set. I am probably
not going to use a dreadnaught body size, but either an OM or SJ.
Any tricks or words of advice in building/bracing etc?
Thicker top plate???
Thicker bridge plate???
Thanks again
Andy
PostPosted: Tue Jan 17, 2006 6:01 am
Here's what I've done: don't go any thicker on the top, bridge, or bridge plate. Make the braces slightly taller (maybe 1/16") and that's all you need. The bridge will be bigger in order to fit all of the pins on there.
Resist the temptation to make the neck more bulky too. If you laminate a neck and use carbon rods, you'll be fine with keeping it the same depth as a six string. Of course your width will change.
If you are making a cutaway, make sure your neckblock is the width of your new 12 string neck and not a six string neck. Don't ask me how I know that one. Arrrrrrg.
PostPosted: Tue Jan 17, 2006 6:18 am
Any one have any dimensions for the nut and bridge pin width on a 12 string. That's the one thing that has me thinking.
PostPosted: Tue Jan 17, 2006 8:48 am
    12 strings are not the big a deal , the biggest change is on the bridge and plate. The spacing is still based on the 1 3/4 2 1/4 taper with the 2nd set of strings offset about 1/16 so figure that into the neck.
PostPosted: Tue Jan 17, 2006 8:54 am
What about all those 12 strings with thier tops bellied in?
With Bruce's science project, it seems like a lot of extra force on the neck and bridge with those extra strings.
Just curious.
PostPosted: Tue Jan 17, 2006 9:08 am
John, I think 1 3/4 will be pretty crowded with all 12 strings. I've gone 1 7/8 and been very happy with the playability.
PostPosted: Tue Jan 17, 2006 9:23 am
When I build 12 strings I make three structural changes to the bracing of the
top. 1) the cross brace behind the soundhole needs to be beefier- I go from
1/2" to 9/16", 2) if you are using a conventional "x" brace design I add a 3rd
tone bar coming off the "x" brace, and 3) I increase the size of the bridge
plate 1/2" over my 6 string design. I also do not scallop the top braces. I
learned these changes from Bozo Padudavac, who, in my opinion, has always
made the best sounding 12 strings. I also find these changes eliminate the
tops bellying. I make no changes to the back bracing. I make the neck in the
same way as a 6 string but the freboard is wider 1 7/8" - 2 5/16". Therefore
the fingerboard taper is slightly different than my 6 strings. I hope this
helps!
Sylvan
http://www.wellsguitars.com
PostPosted: Tue Jan 17, 2006 9:52 am
Andy
PostPosted: Tue Jan 17, 2006 10:23 am
Thanks also.
